gixxerman600 Posted April 29, 2008 Share Posted April 29, 2008 I want to spray bedliner from the door seam down to protect from flying rocks the tires throw. Am i crazy or has anyone done this too.By the way this is my 99'XJ. Link to comment Share on other sites More sharing options...
Rokhound Posted April 29, 2008 Share Posted April 29, 2008 if you go to Pirate I think its Muddypaws has done it to his XJ I will get the link when they get Pirate back up again. Link to comment Share on other sites More sharing options...
Pete M Posted April 29, 2008 Share Posted April 29, 2008 It's been one of the best things I did to my truck in the way of looks. Unless you touch them, you'd never know I didn't have rockers any more. :D A few words of warning. Don't use Rhino Liner for intricate work like this. The process by which Rhino Lining is applied is complex (to say the least) and does not lend itself to detailed work. Do not plug up any drainage holes in the door, the seams, or the rockers. Make sure you properly prepare the surface. Different manufacturers may have different steps for this. Notice all the drips and the overspray that's peeling away from the frame and undercarriage. :mad: Link to comment Share on other sites More sharing options...
gixxerman600 Posted April 29, 2008 Author Share Posted April 29, 2008 I pulled the plastic trim off (looks mutch better)and i want to go from were the top of the moldtnd used to be down to the pinch seam.I thank i will use duplicolor. Link to comment Share on other sites More sharing options...
86FUBAR Posted April 30, 2008 Share Posted April 30, 2008 alot of vehicles came from the factory with a coating like that on the rockers , but i wouldnt everthink of using duplicolor on that , i used that crap on the interior of my manch and i hate it, i used the hurcaliner on the bed and it was ok . i would sugest the hurcaliner befor the duplicolor . Link to comment Share on other sites More sharing options...
