tkgibbs27 Posted April 29, 2008 Share Posted April 29, 2008 is a 5spd tranny with a 4 banger bellhousing able to be converted for the 4.0L? Link to comment Share on other sites More sharing options...
MiNi Beast Posted April 29, 2008 Share Posted April 29, 2008 Meaning if you had the 4.0 bellhousing? I don't think so but someone will chime in with the right answer to be for sure. Try this... http://www.comancheclub.com/forums/view ... ger+tranny Link to comment Share on other sites More sharing options...
jeepthing07 Posted April 29, 2008 Share Posted April 29, 2008 is a 5spd tranny with a 4 banger bellhousing able to be converted for the 4.0L? no Link to comment Share on other sites More sharing options...
tkgibbs27 Posted April 29, 2008 Author Share Posted April 29, 2008 well that's a bummer then. i couldn't put in a t-case with the tranny i have now either i suppose? Link to comment Share on other sites More sharing options...
JeepcoMJ Posted April 29, 2008 Share Posted April 29, 2008 4 cylinder 5 speed is an ax5. i blow them up regularly witha motor that's got similar power outputs...so i have to baby them. I'm trying to find an ax15 for just that reason. you need an ax15, or a peugot ba10/5. someone would be willing to GIVE you their peugot i'm sure. as for t-case, it depends on which tranny you have, and whether or not you have the right input shaft. ...on older ax5's, you need a long input shaft, 21 spline. on newer ones, you still need 21 spline, but a short input shaft would work fine. this widens your choices. Link to comment Share on other sites More sharing options...
