I'm going to be replacing my brake line for the rear brakes today.
The truck is at my buddies house 30 min. away and I would like to pick up the stuff on the way there.
I did somne searching on here and found out the hard line size is 3/16" but 3 different sizes of fittings.
What size(s) do I need to replace the line from front to back?
I did just replace the line from the front brake valve (under the master cylinder) to the rear height sensing proportioning valve above the rear axle. The lines are 3/16 as you said, and IIRC the only size fittings I encountered were 3/8 and 7/16. Make sure you use line wrenches and not a regular open end wrench.
The original line was two pieces with with the coupling just in front of the gas tank, I replaced it in 3 sections. The front section is a PIA because of all the bends required to get from the top of the engine compartment to the bottom without interfering with the steering. I used 2 60" lines and one shorter one which I believe to be 40". The shorter one I used for the front, with the two longer ones for the relatively straight shot along the frame and to the rear valve. I did have to make a small zig-zag to the front and back along the frame rail to use up a little extra length.
I did not replace any other lines as the rest seems to be on okay shape.
I do believe I replaced the air box to have easier access to the front brake valve block. All that's needed for that is a regular metric socket set with a few extensions.
My tally:
3 length of brake line
2 couplers to connect the sections together
2 3/8" / 7/16" line wrenches
1 metric socket set
2 brake adjusters (mine were rusted stuck)
2 quarts of brake fluid (bled the old dark brown fluid from the whole system)
3' 3/16" hose used for bleeding. 1/4" may work better.
1 empty, clean mayonnaise jar used for bleeding
Good luck!
I changed my prop valve over to a XJ one.. and I remember there being a metric fitting on the rear line for some reason at the prop valve. I might be wrong on this.
It gives the flare nut sizes on http://www.madxj.com/ in the brakes/96 booster article.
