just got in the MJ, started it right up.... pulled the e-brake and it shut off..... turn the key..... NOTHING..... open the hood and smell an electrical burning smell over by the relay/ battery area....... WHAT HAPPENED??????
'88 MJ 4.0
I would check fuses and what have you first.
Then I would probably check around the e-brake for hanging wires that may have been pinched or cut when you pulled the ebrake.
Your ebrake is in the center console or on the floor?
I would look by the fuse box under the drivers side. I think the e-brake cable is routed that way. Like twojeeps said maybe your ebrake pinched a wire and grounded it. Or it could be totally unrelated.
e-brake is next to clutch. it did rub the wire a little, but did not pinch. fuses are good. still nothing but the buzzer when i turn the key. lights work.
fuses anywhere else??
could it be the relays by the battery or something else in that area???
i see no burnt wires.
HELP and THANKS!!!!!!!!!!!!
