2.5 blocks
alright, I just picked up a 94 cherokee 2.5 5 speed 4wd for $200. overall it's in decent shape for a beater but...
the engine is toast. all 4 cylinders are scored to $#!&. I could hone out 3 of them and fix that, but the 4th I'm not sure if I can do anything to save it.
anyways, I have another 2.5 block laying in the shop...it's a good block, from an 87 or 88 something like that. it had a spun rod bearing so it's got a bad rod and crank unless i wanted to have those fixed.
so, I'm wondering if the blocks are pretty much identical. can I just use the 94 gasket set? I'm going to swap the crank and one rod from the 94 into the other block, and rebuild it...I figure for $200 and another $150 worth of gaskets, rings, rod, and main bearings, I can't go wrong on a decent DD.
here may be a start for you it appears that the wrangler 4banger is good from 87-up
then you have the jeep that states 87-90 http://"http://www.precisionengine.com/rebuild-kits
:dunno: whats the beef between the two. good luck jamminz.gif
AFAIK the short block is the same for all years. The 2.5L was changed from a Renix-based system to a Mopar injection/ignition in 1991, just like the 4.0L, but I don't they made any significant changes to the block.
Only change I know of was the fuel pump from 86-87. Mechanical to electric. other than that I think you should be OK.
mechanical was the 2.8 in 86. 2.5 was electric fuel pump. maybe 84-85 xj 2.5 was mechanical, as it was carbeurated.
IIRC, when I was looking around for info on adding a turbo to the 2.5 people were saying that the Renix and ChryCo blocks were made of different materials; that one or the other was able to handle the extra strain better. Not sure if there's any truth to this one though. Just what I've read.
