Yeah, this was my post originally. I did have one of these ZJ overhead consoles w. ambient temp and map lights from a 95. It is self contained; all you need to add is IGN and constant power, ground, and the temp sensor, and will work fine in an MJ size-wise. I decided to go a different route by building in a Benz ambient temp display in my existing clock, and adding an auto dimming mirror w. map lights. But since I've found another overhead console even smaller w. Homelink, sunroof switch, and more lights. So I'm getting all the stuff I need to get this functional, including the sunroof.
Are you seeing any pictures?
no, I think that's a fairly old thread. I was only referring to the written content in the thread.
hornbrod:
sounds fancy.........how did you like the zj console when you had it? And what did you have to do for a temperature gauge?
This would make a good write up for the DIY section. :smart:
