what are these?
I agree with Pat,
They are for switches. As the MJ shares the wiring harness with the XJ, there are a number of switches that fit in those four slots at the base of the instrument panel. Some never even avalible in the MJ.
Fog lites, defroster, AW4's power/economy and one other I cannot remember...
CW
can't remember the rear wiper? :P
the one with pink wiresis for the factory cargo light. the one with green is for the factory fog lights.
the cargo one is already wired, you're just missing the switch, a bulb for the indicator (the other little sockets in there), and the cargo light itself.
the fog light...i'm not sure how far that runs. but if you put a factory switch in and flip the switch, it will light up. I believe it only extends so far as the firewall as the factory fogs had a seperate, relayed harness after that.
They look like wires with plugs connected to them to me. :D
Sorry, other than that obvious one, I'm no help, but I do think that John and Jeepco are correct though. I have a couple of them same plugs that aren't being used, and had been wondering the same thing.
