james750 Posted March 11, 2008 Posted March 11, 2008 I'm looking at installing a new rollbar in my mj. ive never done this b4. is there any threads with install and pics. or does anybody have pics of there set up with instructions to base my install off of. it is a bolt in style. Thanx in advance :D
CWLONGSHOT Posted March 12, 2008 Posted March 12, 2008 I have a number of pics of mine in my build thread. Mine was from a Ford ranger SPLASH. I had to widen it to properly/aesthetically fit the MJ. the install is nothing... put it in so you like the look. Check under the bed to be sure there is access to the area you will need to drill. Drill and bolt it in... CW OH yea.. be sure to take pics along the way and POST THEM!!!
james750 Posted March 12, 2008 Author Posted March 12, 2008 Oh, i thought i had to tie it into the frame or something.thanx, ill be sure to post pics 4 sure.
89eliminator Posted March 12, 2008 Posted March 12, 2008 if you want the rollbar to somewhat structural, then you should tie into the "frame". if you just want a "showbar", then just bolt it to the bed.
james750 Posted March 12, 2008 Author Posted March 12, 2008 Yeah, i definitely want to tie it into the frame. I saw a thread for frame tie in brackets earlier on the tech forum, was that for this kind of application?
89eliminator Posted March 12, 2008 Posted March 12, 2008 Yeah, i definitely want to tie it into the frame. I saw a thread for frame tie in brackets earlier on the tech forum, was that for this kind of application? Pete posted this pic. This is what you will need.
