Do they make replacment T-stat housings?
Mine has some pitting in it so I thought I'd replace it. But I cannot find it at the parts houses.
Thanks,
Ron
I've gotten them at AutoZone before.
Hesco makes a nice high-flow one for not much money (around $30 if I recall correctly) that increases the flow capacity quite a bit. I run it on my XJ and have been happy with the results.
The one in the picture doesn't even look ported... If it is mine flowed better...
About 15 minutes of time max will make the $9.00 perform just as well as a ported one..
In my '95 4.0 HO I run a Robertshaw thermostat with the outlet I ported. I warms up quickly and hold a nice stable temperture.
It's way better then my '94 4.0 HO XJ with a non-ported outlet with the stock thermostat
