88JeepManche Posted March 8, 2008 Share Posted March 8, 2008 My truck curently has the BA10 and i trashed reverse today which now gives me an excuse to swap to the AX15. My truck is a 4.0L btw. How hard is this and what all will i need? How can i identify the AX15 in a junkyard? Link to comment Share on other sites More sharing options...
aerocorey Posted March 9, 2008 Share Posted March 9, 2008 http://www.jeeptech.com/trans/ax15.html http://www.jeeptech.com/trans/ba10.html What year is your MJ? Most of the BA 10s have the 21 spline output. All AX-15s are 23 spline outputs. Depending on what you've got your transfer case input might not be interested in accepting a 23 spline output. You can replace the input if yours is a 21 spline. You can also grab an AX-15 with a transfer case still attached if you don't care to check or swap transfer case inputs. A quick search at www.napaonline.com shows different clutches too. EDIT: Just noticed your screen name. If yours is an 88 I'm reasonably certain it's going to be a 21 spline. If I'm wrong someone will correct me. I'm also assuming yours is a 4x4. Not sure if there's a driveshaft length difference in the 2WD BA 10 vs. 2WD AX-15. I don't think there is. Link to comment Share on other sites More sharing options...
skinut88 Posted March 9, 2008 Share Posted March 9, 2008 Anyone know whats diffrent between the clutches i swapped the Ba-10 and used the same clutch seems fine just wondering if it makes a huge diffrence. Link to comment Share on other sites More sharing options...
Oizarod115 Posted March 10, 2008 Share Posted March 10, 2008 Anyone know whats diffrent between the clutches i swapped the Ba-10 and used the same clutch seems fine just wondering if it makes a huge diffrence. same clutch and slave assembly will work just fine. same *stuff* different pile Link to comment Share on other sites More sharing options...
88JeepManche Posted March 14, 2008 Author Share Posted March 14, 2008 How can i tell the difference between the AX-15 and the BA-10 if i find one at the J/Y? Link to comment Share on other sites More sharing options...
Pete M Posted March 14, 2008 Share Posted March 14, 2008 The Peugeot case splits into a left side and a right side. The AX-15 has a front half and a rear half. Also, only look behind 4.0Ls, as the AX-5 found behind 2.5Ls looks like an AX-15, but they are not in any way interchangeable. AX-15 on the left. Notice the line of bolts at the split along the top of the Peugeot. There's a matching line along the bottom too. Link to comment Share on other sites More sharing options...
88JeepManche Posted March 14, 2008 Author Share Posted March 14, 2008 Cool thanks Pete! Link to comment Share on other sites More sharing options...
