Sets lower on lf
Ok here goes. I installed my lift kit and the left front sets 1 inch lower. When i got the truck it had some spring spacers and crap put in the left front to make it set level. I just figured the spring was broke down. Installed the new lift springs and it still set one inch lower. I have looked over the inner fender to make sure it has not been crashed or bent and still can't find anything wrong. Just wanting to know if anyone else has ran into this problem?
I installed a 1/2 inch spacer under the spring and installed 4 of those pop in rubber spacers i think i will go but a regular one inch spacer and install it on the top. I have it close to setting the same in the front now. I have looked this thing over from front to rear no cracks or bends in the frame. It also drives like new and it has 180,000 on it. comancheB.gif
