DansGreyMj Posted April 25, 2006 Share Posted April 25, 2006 ive seen them installed both ways but which way is better the isolator first or the coil spacer first Link to comment Share on other sites More sharing options...
Pete M Posted April 25, 2006 Share Posted April 25, 2006 Depends if the spacer (poly?) will squeak against the coil. I would keep the rubber isolator in contact with the coil 'cause I know it will be quiet. Link to comment Share on other sites More sharing options...
Bounty Hunter Posted April 25, 2006 Share Posted April 25, 2006 Remove the isolator, install the spacer, and then reinstall the isolator. Keep in mind that OEM isolators are stackable to customize the lift height. Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted April 26, 2006 Share Posted April 26, 2006 Other than the squeaking, Pete mentioned, it dosen't really matter. You could do this either way. Â CW Link to comment Share on other sites More sharing options...
comanchedude Posted April 27, 2006 Share Posted April 27, 2006 I would think the spacer against the body then the isolator this would provide a solid stable mounting place for the spacer thats my 2cent Link to comment Share on other sites More sharing options...
