87manche Posted April 25, 2006 Share Posted April 25, 2006 So, since my truck had that roll pan on it, the spare tire winch hadn't been used. I took it all apart and repaired/greased it. It works fine now, but I think a PO has cut the end of the tube where you put the jack in to operate the winch. I had to crank up the spare tire laying on my back and using a pair of vise grips on the tube. Can anyone take a picture of what their spare tire winch looks like right under the bed. I just want to know what I need to make. I'm not looking forward to ever getting the tire back down if I have to lay on the ground, and you know it will be raining, cause flat tires don't happen in nice weather. Link to comment Share on other sites More sharing options...
512tr Posted April 25, 2006 Share Posted April 25, 2006 Will this pic help you? Link to comment Share on other sites More sharing options...
87manche Posted April 26, 2006 Author Share Posted April 26, 2006 hmm, that's exactly what mine looks like. I thought the crimp in the tube was from a PO doing what I did with vise grips. Thanks for the pic. So Let me rephrase my question. Does anyone have a pic of what goes in the tube to make it work? I assume a stock jack handle. Will one from an XJ work? Link to comment Share on other sites More sharing options...
Pete M Posted April 26, 2006 Share Posted April 26, 2006 It'll look like a real big flathead screwdriver, found on the other end of the stock lug wrench. Link to comment Share on other sites More sharing options...
87manche Posted April 26, 2006 Author Share Posted April 26, 2006 sweet. Sounds like I"m just going to make one. A few pieces of flat bar stock and I'll be all set. Link to comment Share on other sites More sharing options...
Eagle Posted April 26, 2006 Share Posted April 26, 2006 The factory jack and handle for the MJ is exactly the same as for an XJ. Just hit the u-pull yard and look under the back seats of the XJs. Link to comment Share on other sites More sharing options...
87manche Posted April 27, 2006 Author Share Posted April 27, 2006 that's what I needed to know. I'll go yarding and find the stock lug wrench and jack handle from an XJ. Link to comment Share on other sites More sharing options...
mjeff87 Posted April 27, 2006 Share Posted April 27, 2006 This is the object of your desire. It scissors open, and the end that goes into the cable un-winder is spoon shaped: Image Not Found Link to comment Share on other sites More sharing options...
87manche Posted April 27, 2006 Author Share Posted April 27, 2006 that certainly looks like it. I'm gonna have to see if that 90 being parted still has it's deal there. Link to comment Share on other sites More sharing options...
