akamcbird Posted February 26, 2008 Share Posted February 26, 2008 oil gage is bouncing in the 80 range and beond what does this mean? bad sending unit? '90 eliminator 4.0 Link to comment Share on other sites More sharing options...
mfpdm Posted February 26, 2008 Share Posted February 26, 2008 The sending units that have gone bad on me did the opposite but that don't mean they can't bounce the other way. Mine would read right until I stopped, then bounce down to zero in pressure. The spring inside them crap out and make the pressure gauge wrong. I'd say you have a very good chance it's the sender. edit: If anything, it should be the cheapest part to replace to find out if that is your problem. :cheers: Link to comment Share on other sites More sharing options...
BLHTAZ Posted February 26, 2008 Share Posted February 26, 2008 Agreed...replace the sender. Link to comment Share on other sites More sharing options...
Eagle Posted February 26, 2008 Share Posted February 26, 2008 Pull the wire off and see where the needle goes. Then ground the wire directly to the block and see where the needle goes. I can never remember which is which -- one should zero the gauge, the other should peg it beyond 80. If that works, the gauge is okay. If the connecter looks good, then replace the sending unit. Link to comment Share on other sites More sharing options...
akamcbird Posted February 27, 2008 Author Share Posted February 27, 2008 working properly today i guess its on its last leg...or mile? thnx for the knowledge ill be fixing that soon Link to comment Share on other sites More sharing options...
