Geonovast Posted February 19, 2008 Share Posted February 19, 2008 One of my neighbors has a 2000(I believe) Saturn Station wagon. 4cyl Auto. It suddenly decided it won't start. It turns over, I'm 99% sure it's getting spark, and it does get a little bit of fuel. Got a few puffs of exhaust. You can hear the fuel pump prime, and I checked the fuel pump and ignition fuses, they're fine. I'm thinking the fuel pump is dead or dying, and not getting enough pressure to run. Any ideas? Link to comment Share on other sites More sharing options...
BLHTAZ Posted February 19, 2008 Share Posted February 19, 2008 Sounds like a likely scenario to me. The only thing you can do to confirm it is find out what the fuel pressure is supposed to be and test it. Link to comment Share on other sites More sharing options...
ifixit8 Posted February 19, 2008 Share Posted February 19, 2008 how many miles? and after you check fuel press, i'd check the timing belt. those cars love to throw a timing belt at about 100k. Link to comment Share on other sites More sharing options...
dragonrider477 Posted February 19, 2008 Share Posted February 19, 2008 x2 on checking the fuel pressure.also,see if it will run on starting fluid.if it does suspect weak/no fuel pressure.all 4 cyl saturns have a timing chain,not belt.and yes,the chains do woof on these cars with high mileage. Link to comment Share on other sites More sharing options...
mvusse Posted February 20, 2008 Share Posted February 20, 2008 Without being there to see and hear exactly what it does (including rythm) my bet is on the timing chain/sprockets. Link to comment Share on other sites More sharing options...
ifixit8 Posted February 21, 2008 Share Posted February 21, 2008 all 4 cyl saturns have a timing chain,not belt.and yes,the chains do woof on these cars with high mileage. sorry my bad, was very tired the other night when i typed it. Link to comment Share on other sites More sharing options...
Geonovast Posted February 21, 2008 Author Share Posted February 21, 2008 I doubt it's the chain. If it had broke I'm sure I'd head something clinking around inside the timing cover. Also, if it did break, it's definitly and non-intereference motor cause I'm not hearing any valves bending. I do not have a fuel pressure tester, otherwise I would've checked that already. Gonna have to get ahold of one. I'm not sure on the mileage, but I know he did get a new motor within the last several years. Link to comment Share on other sites More sharing options...
FxRacing282 Posted February 21, 2008 Share Posted February 21, 2008 maybe the MAS sensor is no good? Link to comment Share on other sites More sharing options...
mvusse Posted February 22, 2008 Share Posted February 22, 2008 I have had timing chain problems where the chain was fine, but the nylons teeth on the sprocket had wore down. The crank sprocket was moving the chain, but it was just sliding over the cam sprocket... Link to comment Share on other sites More sharing options...
