swap out 207 for the 231
is it a direct swap or at least close to direct swap to ditch the 207 for the 231? i thought it was but sorta recall some one probably jeepco saying that there was more involved? . o and I'm sportn the ax5
shaft length. get a 21 spline 231 with a long input shaft. that will work
the 231 geonovast and I had at hand (from a ba10/5) had a short input and would not have sealed up properly...weeping fluid isn't good. other than that one problem, it's easy.
OH and there IS a kit out there somewhere, and also a seal that has a longer piece on it so you can use the short input on a tranny that requires long input. no idea where, but i've been told it is.
