lower jeep Posted February 13, 2008 Share Posted February 13, 2008 I'm getting readdy to build a 4.7 stroker motor :D and i was wondering what is the best way to clean the piston rods can i sandblast them or just soak them in some degreaser? also where can i get a complete gasket set cheap? i called around and found the cheapest Fel Pro gaskets for like $103 for the upper and $33 for the lower parts of the motor, is this a good price for these? Thanks Lower Jeep Link to comment Share on other sites More sharing options...
JeepcoMJ Posted February 13, 2008 Share Posted February 13, 2008 #1 stroker, and cheap gaskets don't mix. buy quality unless you want to take it apart again #2 no, you shouldn't sandblast the piston connecting rods. you run the risk of destroying the bearing surfaces for the wrist pin, and the surface for the rod bearings. you CAN clean it using a bead blaster (media cabinet, a.k.a. a smaller version of a sandblaster that uses either very fine sand, or glass beads depending) but be careful on the bearing surface. I'd probably clean it with a parts washer, and call it a day once they're clean and dry. Link to comment Share on other sites More sharing options...
BLHTAZ Posted February 13, 2008 Share Posted February 13, 2008 #1 stroker, and cheap gaskets don't mix. buy quality unless you want to take it apart again #2 no, you shouldn't sandblast the piston connecting rods. you run the risk of destroying the bearing surfaces for the wrist pin, and the surface for the rod bearings. you CAN clean it using a bead blaster (media cabinet, a.k.a. a smaller version of a sandblaster that uses either very fine sand, or glass beads depending) but be careful on the bearing surface. I'd probably clean it with a parts washer, and call it a day once they're clean and dry. Absolutely agree... You do not want to go "cheap" on anything when building a stroker, you will only cause yourself grief and end up costing you more money than it would have to do it right to begin with. There is a group of "Jeep Stroker" folks that have a Yahoo group right now and will very soon have a website & normal forums. These guys know their stuff about strokers so keep an eye out for www.JeepStrokers.com to be up and running within the next few days hopefully. Link to comment Share on other sites More sharing options...
FxRacing282 Posted February 13, 2008 Share Posted February 13, 2008 for the connecting rods... i would just get new ones to be honest with you. no point in running the risk of used connecting rods. if you are going to use stock ones i would use a dremel and clean them up and remove any hard edges EXCEPT around the bearings Link to comment Share on other sites More sharing options...
