Salvagedcircuit Posted October 7 Posted October 7 I have the annoying 16 gallon gas tank. I'm upgrading to the 23gallon but I need the correct Long Bed 23 gallon Fuel pump sender/pickup assembly. Can paypal asap Thanks!
fiatslug87 Posted October 10 Posted October 10 Well, I have three sending units, the one on the right (1st pic) is labeled as ‘90 23gal. The left and right one both have a tag with 89560 01859 (my SWB and LWB have this) middle has 5345. All three look the same except as follows. The right one has a different upper pump bracket than the other two. The middle one has 90° hoses coming to it. Anyone have any insight?
eaglescout526 Posted October 10 Posted October 10 18 minutes ago, fiatslug87 said: Well, I have three sending units, the one on the right (1st pic) is labeled as ‘90 23gal. The left and right one both have a tag with 89560 01859 (my SWB and LWB have this) middle has 5345. All three look the same except as follows. The right one has a different upper pump bracket than the other two. The middle one has 90° hoses coming to it. Anyone have any insight? Brass ones are 86 sending units. They can be used with the smaller Bosch ones that replaced the bigger style.
fiatslug87 Posted October 10 Posted October 10 @eaglescout526 so the 90 would suit Salvagedcircuit better?
eaglescout526 Posted October 10 Posted October 10 3 hours ago, fiatslug87 said: @eaglescout526 so the 90 would suit Salvagedcircuit better? Yes. Unless he has the smaller pump ready to go in.
