emosun Posted September 23 Posted September 23 Bought in july 2026 for 1000$ . First jeep I ever owned but probably the 40th car I've ever bought. 1987 4.0 / 5spd manual / 4wd 230k+ Still runs and drives but extremely rusty. The floors had been entirely replaced with bits of metal and self tappers and flex seal by someone at some point. Both bed sides had rust holes the size of basket balls. 60% of the frame on the driver side was rotted and missing between the cab and bed. These are the original photos of it from the sales ad. Test drove it and it actually drove really well. Major issues at the time were frame rot / parking brake / engine mounts.
emosun Posted September 23 Author Posted September 23 Replaced front wheel bearings and brakes and parking brake and welded the frame in july/august. Repaired the bed sides with door skins on one side and a roll of steel on the other. Painted with a can of sherwin williams color match oil paint and a brush. Not great but better than it was. Replaced driver side door. Took about 10lbs of rust out of the rear bumper and repainted it. Repainted wheels. Also replaced a ton of wiring that was all done with house wire nuts
Andyfrye Posted September 23 Posted September 23 Wow! That is a lot of rust. What are your plans? Complete rebuild or just make it last longer?
emosun Posted September 24 Author Posted September 24 13 hours ago, Andyfrye said: Wow! That is a lot of rust. What are your plans? Complete rebuild or just make it last longer? Definitely not a complete rebuild. This is what most car guys would consider to be a parts car. Not a candidate for an expensive rebuild. I actually however get a lot of enjoyment from buying the worst example of something and keeping it going. I like seeing the history and the patches and repairs along the way that add to the story of the car and show it's age. It's far more interesting to me to see how a car survived than to totally erase it's entire past.
emosun Posted September 24 Author Posted September 24 Reusing leftover interior window sweeps as exterior window sweeps
emosun Posted October 9 Author Posted October 9 Installed free house carpet. I had a new roll of this just sitting in the garage and the color isn't half bad all things considered. Good enough for a cheap work truck
emosun Posted October 19 Author Posted October 19 Re-did my own crappy bodywork on the driver side that I originally did with thin sheet metal and used two more junkyard door skins from a cherokee. Looks slightly better than it previously did and is much more durable. Also rolled on some bed liner. I did consider simply repainting the bed red... but I realized how quickly and easily it will get scratched up by me using it. So I opted to go for the black bed liner look instead.
Gojira94 Posted Thursday at 04:43 PM Posted Thursday at 04:43 PM One of the best "thoughtful preservation" jobs I've ever seen. Very clever idea on the window sweeps, for sure. Enjoy your work truck!
