NickyV Posted 4 hours ago Share Posted 4 hours ago I'm looking at doing my head gasket. Trying to figure out which bolts I need. It's a 1987 2.5L. I'm not seeing any kits online specifically for the 2.5L, and based on the 1987 parts manual, it's not entirely clear to me how many I need with studs vs without studs. It just says "AR" or "use as required." But I'd like to replace them all. Pretty sure I need 10 total, but can anyone tell me with certainty how many I will need of #10, #9 and #8 to replace all of them? Link to comment Share on other sites More sharing options...
eaglescout526 Posted 3 hours ago Share Posted 3 hours ago Yeah you need ten. When I did this I ordered new bolts fro ARP I think. Man it was many years ago. If your head bolts come out in hood rust free shape, don’t hesitate to reuse them. If they come out questionable like how bolt 7 probably will because it sits in the water jacket, then I’d get new ones. As far as the two measurements go for 8 and 9, im not sure. You’d have to see what comes out of your head when you do the gasket. But if I recall when I did mine, there supposed to be 3 of the studed bolt. You can always look at what’s on now. Maybe try searching “Jeep 2.5L head bolts” and see what pops up. Pretty sure the bolts went to a 12 point bolt head later on like in the HO years but there should be the hex head too. Link to comment Share on other sites More sharing options...
NickyV Posted 1 hour ago Author Share Posted 1 hour ago Thanks. I gathered that things changed in the HO years. But I've also read that at some point around 1987, they started using torque-to-yeild bolts. Really want to make sure I do it right! Link to comment Share on other sites More sharing options...
NickyV Posted 1 hour ago Author Share Posted 1 hour ago Lol. I definitely didn't read the parts manual closely enough. It literally says I need five of the 3.75", one of the 4.52" and the rest are "as required," which would be four. And that is exactly what it looks like under my hood too. Link to comment Share on other sites More sharing options...
