Oil Pump
29 minutes ago, Drahcir495 said:
Going to put a new oil pump in the XJ. Should I get a high volume pump? And what brand do you recommend?
If you have an engine with older (worn) bearings, a high volume pump “might” be beneficial over a standard pump.  Regardless of pump type, I would recommend using one made my Melling.
