Sensor issues.
My oil pressure has been spiked at 80/70 psi for a while now and my temp gauge read 210 at the line below 210. Replaced both the oil pressure gauge stayed the same and now the temp gauge does not work at all. Could there be something wrong in the cluster it self causing this? I am having fuse issues and my gauge cluster lights don't seem to be turning on at all anymore
Could be instrument cluster ground. I have the same issue, but have yet to fix it. My battery gauge is constantly reading 2-3 volts low. When I mess with the dimmer switch, my coolant temp needle spins around the gauge like crazy. Even if that's not the root cause it definitely won't hurt to do the fix. Cruiser tip 18
13 hours ago, eaglescout526 said:
Are you sure its a sensor? Maybe you got the sender by accident?
Edit, I just saw your build thread, that is a sensor. Carry on!
Yeah weird that it just does not work at all anymore I don't wanna put the old one back in cause it does not work right and that little hole pours coolant out like no kther
