Muncher Posted October 31, 2025 Share Posted October 31, 2025 My oil pressure has been spiked at 80/70 psi for a while now and my temp gauge read 210 at the line below 210. Replaced both the oil pressure gauge stayed the same and now the temp gauge does not work at all. Could there be something wrong in the cluster it self causing this? I am having fuse issues and my gauge cluster lights don't seem to be turning on at all anymore Link to comment Share on other sites More sharing options...
hgeranium Posted October 31, 2025 Share Posted October 31, 2025 17 minutes ago, Muncher said: My oil pressure has been spiked at 80/70 psi for a while now and my temp gauge read 210 at the line below 210. Replaced both the oil pressure gauge stayed the same and now the temp gauge does not work at all. Could there be something wrong in the cluster it self causing this? I am having fuse issues and my gauge cluster lights don't seem to be turning on at all anymore Could be instrument cluster ground. I have the same issue, but have yet to fix it. My battery gauge is constantly reading 2-3 volts low. When I mess with the dimmer switch, my coolant temp needle spins around the gauge like crazy. Even if that's not the root cause it definitely won't hurt to do the fix. Cruiser tip 18 Link to comment Share on other sites More sharing options...
Muncher Posted October 31, 2025 Author Share Posted October 31, 2025 Yeah not a bad idea I forget if I did that ground or not. My fuel gauge tach and volt gauge work just fine so it's weird Link to comment Share on other sites More sharing options...
eaglescout526 Posted October 31, 2025 Share Posted October 31, 2025 Are you sure its a sensor? Maybe you got the sender by accident? Edit, I just saw your build thread, that is a sensor. Carry on! Link to comment Share on other sites More sharing options...
Muncher Posted October 31, 2025 Author Share Posted October 31, 2025 13 hours ago, eaglescout526 said: Are you sure its a sensor? Maybe you got the sender by accident? Edit, I just saw your build thread, that is a sensor. Carry on! Yeah weird that it just does not work at all anymore I don't wanna put the old one back in cause it does not work right and that little hole pours coolant out like no kther Link to comment Share on other sites More sharing options...
eaglescout526 Posted October 31, 2025 Share Posted October 31, 2025 Have you removed the oil gauge at all? Link to comment Share on other sites More sharing options...
