Don Chair Posted August 27, 2025 Share Posted August 27, 2025 My stock tail lights don't work anymore and I am looking for some replacements. Attached below are the only ones I can find. They are fairly expensive, which I get because the Comanche isn’t a popular vehicle. Does anyone know if there are any cheaper alternatives? Also in the reviews for these taillights one mentions needing a LED flasher relay? I don’t know what that is because I am in no way shape or form a mechanic or have much knowledge I’ve been working on my truck with a buddy who knows way more than I do. Thanks for the help in advance. https://www.amazon.com/ORACLE-Lighting-Lights-1986-1992-Comanche/dp/B0CFP1VZQT Link to comment Share on other sites More sharing options...
Pete M Posted August 28, 2025 Share Posted August 28, 2025 key parts make factory style replacements plus separate lenses to swap on to you housings. ebay will also have a variety of used housings. the flasher relay just replaces the turn signal pots in the fuse box. https://www.ebay.com/sch/i.html?_nkw=jeep+comanche+taillights+key+parts&_sacat=0&_from=R40&_trksid=p2334524.m570.l1313&_odkw=jeep+comanche+taillights&_osacat=0&_sop=16 Link to comment Share on other sites More sharing options...
89 MJ Posted August 28, 2025 Share Posted August 28, 2025 What do you mean your tail lights don’t work anymore? I think you might be having an issue with a ground or with wiring. Link to comment Share on other sites More sharing options...
Don Chair Posted August 28, 2025 Author Share Posted August 28, 2025 14 hours ago, Pete M said: key parts make factory style replacements plus separate lenses to swap on to you housings. ebay will also have a variety of used housings. the flasher relay just replaces the turn signal pots in the fuse box. https://www.ebay.com/sch/i.html?_nkw=jeep+comanche+taillights+key+parts&_sacat=0&_from=R40&_trksid=p2334524.m570.l1313&_odkw=jeep+comanche+taillights&_osacat=0&_sop=16 Thanks! I think I’m just gonna go ahead and get the new LEDs as they are much brighter and I won't have to keep messing with replacing halogens. Link to comment Share on other sites More sharing options...
Don Chair Posted August 28, 2025 Author Share Posted August 28, 2025 12 hours ago, 89 MJ said: What do you mean your tail lights don’t work anymore? I think you might be having an issue with a ground or with wiring. The sockets are corroded and gross but I think I’m just gonna go ahead and invest in the LED lights. Thanks for taking the time to reply though! Link to comment Share on other sites More sharing options...
AZJeff Posted August 28, 2025 Share Posted August 28, 2025 37 minutes ago, Don Chair said: The sockets are corroded and gross but I think I’m just gonna go ahead and invest in the LED lights. Thanks for taking the time to reply though! I installed the LED taillights in my MJ even though I had reworked a set of OEM lights using the new KeyParts lenses. My reason for doing so was to increase taillights brightness, as the MJ taillights were never terribly bright, and I want people to notice my brake lights particularly. The LED light are an improvement, although they are not cheap. I give them a thumbs up for construction quality as well. Link to comment Share on other sites More sharing options...
