Spinnakerblue89 Posted July 16, 2025 Share Posted July 16, 2025 Here it is: I am looking at a pair of Koito H4 headlight upgrades for my Comanche because apparently IPF /ARB 820H is unobtainium. It is my understanding that Comanches and Cherokees use 5x7s (except for Wagoneer Cherokees). However, I also see them being referred to as 7x6- supposedly they are one in the same, just marketed differently. Additionally, I also see those being marketed as 200mm headlights. BJ's is selling Koito E-code RHD 200mm headlights, obviously for full-size Jeeps. There is the link. I've tried researching this and while I'm about 90% sure that 5x7 = 7x6 = 200mm, I want to be more certain because they wasn $165 for a pair of these, and allegedly, they are seriously GOOD. Bottom line, would headlights for a J-Truck/GW fit in my MJ? Oh, and I have had Hellas before and I liked them. I preferred the IPFs and I want to give these a try. Link to comment Share on other sites More sharing options...
89 MJ Posted July 16, 2025 Share Posted July 16, 2025 Yes, those will work. My brother ordered the exact same headlights I put in my Comanche for his J10s and it fit both of them correctly. For what its worth though, from what I have seen and from what my brother has seen, everything BJ's has to offer is typically more expensive than lots of other places. It is a small company though, so there's that. Link to comment Share on other sites More sharing options...
Spinnakerblue89 Posted July 16, 2025 Author Share Posted July 16, 2025 They may be more expensive but the only other option I see for Koito 200mm is Daniel Stern Lighting, and he's more expensive. So I guess I'll bite the bullet and hope it's worth it because I just called ROCO 4x4 to see if they had access to IPFs and they are absolutely 100% discontinued as of 2025. I'm not dead set against Hellas, I mean they work great on my '88 Ranger, but I'm always trying new things to avoid being blinded by product loyalty. It's $65 more than I wanted to spend but Hellas are also about $30 more than I wish. Might as well try them out. I'll probably try these first in my BII to test them when they get here because I'm currently redoing some under hood wiring on the MJ. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted July 16, 2025 Share Posted July 16, 2025 I have a set of rampage housings. Solid glass front and aluminum rear with a very nice beam pattern. For a replacement housing, they are extremely nice Link to comment Share on other sites More sharing options...
Spinnakerblue89 Posted July 17, 2025 Author Share Posted July 17, 2025 18 hours ago, ghetdjc320 said: I have a set of rampage housings. Solid glass front and aluminum rear with a very nice beam pattern. For a replacement housing, they are extremely nice I looked at those but I wasn't sure about them. Do they have plain glass lenses without the diffusion pattern cut into them? I have a set just like that which I took off of my Ranger. Link to comment Share on other sites More sharing options...
