92comanche4x4 Posted January 12, 2008 Share Posted January 12, 2008 I know theres proly a thread about this but how hard is it to do and does any one have a pic sof it when its done like the grille and the fenders i was thinkin that would look sweet Link to comment Share on other sites More sharing options...
Geonovast Posted January 12, 2008 Share Posted January 12, 2008 Yes you can do it, from what I understand it's relatively easy. I know several people on here have done it. I probably would have done it by now, but I prefer the older style. Link to comment Share on other sites More sharing options...
DrThunder Posted January 12, 2008 Share Posted January 12, 2008 look at my signature Link to comment Share on other sites More sharing options...
DrThunder Posted January 12, 2008 Share Posted January 12, 2008 its fairly easy, i didn't do the fenders just cause, the wiring needs to be altered and the mounting is completly different but do-able with a drill and some hardware. Link to comment Share on other sites More sharing options...
92comanche4x4 Posted January 12, 2008 Author Share Posted January 12, 2008 what kinda hardware i would love to do this before i do the bodywork so i can paint it all at once Link to comment Share on other sites More sharing options...
offroader461 Posted January 12, 2008 Share Posted January 12, 2008 to make it look perfect...you need: Header panel, grill, bezels, all the turn and marker lenses, and both front fenders you can bolt everything together like it was meant to be there...swapping fenders is easy the swap requires no wiring what so ever unless you want to run the 2 turn signal bulbs, i just modifyed the marker light holder and it fit perfect when i was doing mine..decided to go back to the older look (Looks better IMO) You can do the swap w/o swapping fender as others have said but the fenders and header are shaped differently Link to comment Share on other sites More sharing options...
Pete M Posted January 12, 2008 Share Posted January 12, 2008 If you swap the front fenders, then your front flares won't match the rear flares. It's not a simple task to swap on rears since MJ rear flares are bigger than XJ rear flares. Although one of our members was patching together a couple sets of 97+ XJ flares to create his own MJ rear flares. Personally, I'd keep the stock front fenders and do my best to blend them into the 97+ header assembly. Link to comment Share on other sites More sharing options...
Car RamRod Posted January 12, 2008 Share Posted January 12, 2008 I agree with pete. I'm gonna do this when I paint my truck in a week or so. I'm not gonna change out the fenders though, it's not really worth it for my truck. Link to comment Share on other sites More sharing options...
