Diagnosing noise from engine bay
Seems like the starter might not be disengaging quickly enough. What do you mean this happens under acceleration too? It could also be a cracked flex plate or the bolts for it have backed out if you have an automatic.
sorry I should’ve specified a bit better, it doesn’t make the initial sound as it does when starting up but it sort of enhances the sound it makes while idling
