Dandxj Posted February 26, 2025 Share Posted February 26, 2025 I have the Distribution Block disassembled and I am cleaning it. I am using a 1/16 in. drill bit to ensure the line ports are clear. The bit goes in fine for all the ports except for the by-pass port on the bottom of the block. The bit enters the port but will not go through to the center. I can insert a small wire through and it is visible looking down the plunger hole. I can blow into the port but it is much more difficult than with the other ports. Does the by-pass port have a reduced size at the bottom ( top if it were in the truck ) or is mine clogged ? Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted February 26, 2025 Share Posted February 26, 2025 This might help. Link to comment Share on other sites More sharing options...
fiatslug87 Posted February 26, 2025 Share Posted February 26, 2025 There's a cut-away pic in this post. Link to comment Share on other sites More sharing options...
Dandxj Posted February 27, 2025 Author Share Posted February 27, 2025 Thanks - I have seen that cut away and it appears that the drilled channel for the by-pass port is the same diameter for its full length from the threaded part up into the center portion for the plunger. Mine is definitely not like that. The 1/16 in. bit slides in fine but stops before entering the bore for the plunger. The wire from a bread loaf tie wrap does go through. I just want to be sure it is suppose to be reduced like that before I do something stupid like drilling it out. Link to comment Share on other sites More sharing options...
