Spinnakerblue89 Posted January 28 Share Posted January 28 Curious what the forum thinks. I have heard advice that once a ground has been thoroughly cleaned and tightened down, it can be covered with spray paint to help prevent corrosion, I've even heard of things such as Zinc primer being used. Not necessarily looking to do this, I'm only asking since I have seen it more than once on several sites, just not here. Thanks. Link to comment Share on other sites More sharing options...
AeroNautical Posted January 28 Share Posted January 28 I've heard of people using "liquid electrical tape" on grounds before, for the exact reason you say. As long as it's tightened down, and nothing you apply to it can creep under the terminal leads (think penetrant like aerokroil or pb blaster), then I don't see any harm in it. I'd use something easily removed, though. No rhino lining, haha. Link to comment Share on other sites More sharing options...
Spinnakerblue89 Posted January 29 Author Share Posted January 29 I see, thank you. I've used liquid electrical tape before and while I find it very handy, I've learned in the past that it doesn't always hold up very well. There's a limit to everything. Link to comment Share on other sites More sharing options...
pizzaman09 Posted January 29 Share Posted January 29 I'm personally a fan of Cruiser's suggestion of Oxgard. It is basically silicone grease with carbon black in it to make it electrically conductive. So the silicone grease keeps moisture and corrosion out while the carbon black allows a better electrical contact to be maintained than if straight silicone grease (dielectric grease) where used. Sure you could paint over it too, but paint isn't necessary a great way to seal a connection, particularly one that can vibrate. Link to comment Share on other sites More sharing options...
Spinnakerblue89 Posted January 29 Author Share Posted January 29 I did use, and do recommend to others that Oxgard be used. I've used it for years on other applications as well. I merely wanted to know what others thought about covering the connection points with spray paint or whatever. Link to comment Share on other sites More sharing options...
coheed Posted January 29 Share Posted January 29 I usually cover mine in dielectric grease. It's clear so you can see if there's rust forming under it so you can clean and reapply. I refreshed the tail light ground on mine a few years ago and no issues so far. Link to comment Share on other sites More sharing options...
