JIMMYRIG Posted November 25, 2024 Share Posted November 25, 2024 I have a crank no start problem that is inconsistent but lately seems to happen after the truck sits for more than 8 hours. At one point I was able to keep shutting the ignition off and back on a few times and that would resolve it. Anyone got a clue what it could be? My hunch is cps but wanted to see other people’s ideas. Thanks! Link to comment Share on other sites More sharing options...
speeding_infraction Posted November 25, 2024 Share Posted November 25, 2024 Have you done cruiser54's tips 1-5? Start there if not. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted November 26, 2024 Share Posted November 26, 2024 35 minutes ago, JIMMYRIG said: I was able to keep shutting the ignition off and back on a few times and that would resolve it. Sounds like it could be your ignition switch. It is located down towards your feet bolted to the steering column. Link to comment Share on other sites More sharing options...
JIMMYRIG Posted November 26, 2024 Author Share Posted November 26, 2024 6 hours ago, TurboedMJ said: Have you done cruiser54's tips 1-5? Start there if not. Thanks I’ll check these out. I forgot to mention some of the other symptoms… Normally I get tach bounce when cranking, however when I have this issue there is no tach bounce until right before I finally get it to start. Also the last couple days I’ve given and just pushed it down the hill to bumpstart. If all else fails bumpstarting seems to work every time. I have other things I know I need to replace like my iac valve but I doubt that is causing the issue Link to comment Share on other sites More sharing options...
Spinnakerblue89 Posted November 26, 2024 Share Posted November 26, 2024 I dunno, the IAC on my ZJ did this very thing just this year. I cleaned it, and it ran again but that valve was freaking rough man. Replaced it ASAP and it started up like it was dying to start up! Link to comment Share on other sites More sharing options...
