SLOTMAN Posted November 24, 2024 Share Posted November 24, 2024 Is there an upgrade radiator with maybe two cores instead of 1 that will bolt in being as I'm changing out the radiator if there is one, company to get it AT and part number would be appreciated also I think an electric fan for slow crawling would also be an appropriate upgrade any thoughts would be appreciated thanks in advance. Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 24, 2024 Share Posted November 24, 2024 I recommend staying far the hell away from the aluminum radiators with plastic tanks on both ends. Crown makes a damn good drop in replacement radiator that I’ve been running with no problem and I’m in AZ and using a mechanical fan. Course I don’t do any crawling. But if I were, I’d look into keeping both mech fan and put an electric fan on the front of the radiator. But the 2.5L also doesn’t run incredibly hot and doesn’t take up 95% of the engine bay real estate to mess with air flow. Biggest thing is making sure the original fan shroud is in great shape and not in pieces. Link to comment Share on other sites More sharing options...
SLOTMAN Posted November 24, 2024 Author Share Posted November 24, 2024 Thank you for the reply sounds like good advice I'm also gonna check water pump and thermostat probably replace all three plus hoses to get the job done right Link to comment Share on other sites More sharing options...
The86manche Posted November 24, 2024 Share Posted November 24, 2024 I was told oriellies has a full aluminum radiator Link to comment Share on other sites More sharing options...
Cami.1987 Posted June 2, 2025 Share Posted June 2, 2025 On 11/24/2024 at 2:35 PM, SLOTMAN said: Thank you for the reply sounds like good advice I'm also gonna check water pump and thermostat probably replace all three plus hoses to get the job done right @SLOTMANAny luck with the replacement? I just moved to Florida and am looking to do the same. Thanks!! 1987 Comanche 4.0L, 4x4, 5-Speed, Short Bed. Link to comment Share on other sites More sharing options...
