will this roll bar fit?
thats a show bar and will not really help if you truly did roll over.
NO "roll bar" will help if you truly roll over, unless it hasmounts below the bed that go to the frame.
but, as stated, it's a bit less strong than others...it's a bolt-together one, so making it a bit narrower won't be a big deal anyways.
Ya exactly that makes it a "show bar" because its there for show not for go.....
well all you would have to do is tie it into the frame some how, make a braket and weld it or bolt it to the frame, your choice. But if its wider just cut like i don't know how many inches out of it in the center and weld it back together with some bracing, then send her off to poweder coat. I'm gonna look for a dakota bar for my truck now since they will fit i guess.
