Warren99 Posted August 1, 2024 Share Posted August 1, 2024 My axle tube seals are leaking on my newish dana44. Does anyone know a part number or anything to find the right seals? I mainly ask because back when I was getting new brake hardware, it was considered odd that I had an XJ dana44 with the 9 inch brake drums instead of 10 inch drums. I wanna make sure I get the right seals. Link to comment Share on other sites More sharing options...
schardein Posted August 1, 2024 Share Posted August 1, 2024 The 87-90 parts manual shows the same part number for the wheel seal on Dana 44s used in the XJ, MJ, and YJ. #83503063. Plug that into Rockauto and you get this: (see pic) Click on "info" for any of those parts and it gives you inside and outside measurements you can compare to your seal. A cheap set of plastic measuring calipers from Harbor Freight are accurate enough for comparison measurements like these. Link to comment Share on other sites More sharing options...
Warren99 Posted August 2, 2024 Author Share Posted August 2, 2024 nvm, found what I needed. I'd delete the thread since it's basically useless but idk how Link to comment Share on other sites More sharing options...
