UpstateMJ Posted July 27, 2024 Share Posted July 27, 2024 Wanted to keep my under hood temps down in this horrible South Carolina heat we have been having. Picked this brand new hood louver up off market place for cheap. Already running 5-10 degrees cooler. My trans tunnel still getting so hot I could cook an egg on it though. Even with carpet and kil-mat. Any suggestions? Link to comment Share on other sites More sharing options...
ghetdjc320 Posted July 28, 2024 Share Posted July 28, 2024 Are you running a catalytic converter? If so, see if it still has a heat shield intact. If it’s missing, get a heat shield for it. Link to comment Share on other sites More sharing options...
zomeizter Posted July 28, 2024 Share Posted July 28, 2024 These do help with the heat, got vents on the XJ but I started having issues with the TPS failing often. Found out the rain was soaking the sensors and destroying them, so I homebrewed a rain cover on the inside/underside of the vent and the problem went away. This may not apply to your setup, but if it does... Link to comment Share on other sites More sharing options...
UpstateMJ Posted July 28, 2024 Author Share Posted July 28, 2024 On 7/28/2024 at 12:24 PM, ghetdjc320 said: Are you running a catalytic converter? If so, see if it still has a heat shield intact. If it’s missing, get a heat shield for it. Expand No cat, but I am running a 2000+ header and intake on a 98 motor. No rear o2 sensor Link to comment Share on other sites More sharing options...
Tex06 Posted July 29, 2024 Share Posted July 29, 2024 Auto or manual trans? Link to comment Share on other sites More sharing options...
UpstateMJ Posted August 3, 2024 Author Share Posted August 3, 2024 On 7/29/2024 at 8:36 PM, Tex06 said: Auto or manual trans? Expand auto, 231 tcase Link to comment Share on other sites More sharing options...
