Gas tank
Ok guys I just put a new fuel pump in my 88 lab, I eventually want to put a new tank on. Yes, I've read previous posts and I've read about 16, 18 and 23.5 gallon tanks. Different people say different things. I can tell you I felt 2 baffles on bottom of tank and I think it has 3 straps.
So question is, is there a definitive way to tell by looking at it?
If not and I currently have 16 or 18 gallon and I buy a 23 gallon by mistake will pump still work or vice versa. What do I have?
If it has 3 straps and you're a long wheelbase/ long bed, that sounds like the 23. A 23 won't fit on a short box.
Sending unit/ pump arrangement is same for all 18 & 23 gallon tanks specific to MJ. XJ sending units are different.
Edited by Gojira94
clarification
If it’s the original tank, it will have a date and gallon plate by the sending unit opening. Long beds came with 16 or 23. 16 will be identified by a shorter arm on the sending unit and the filler tubes inside will be longer than the 23 gallon.
I was not aware of this. MTS makes no distinction about the arm on their units made for 18 & 23, so at least those are the same.
