TheSiLvAPython Posted July 4, 2024 Share Posted July 4, 2024 Are the ring and pinion gears the same for non c clip and c clip axles? And are the interchangeable? Link to comment Share on other sites More sharing options...
ghetdjc320 Posted July 5, 2024 Share Posted July 5, 2024 6 hours ago, TheSiLvAPython said: Are the ring and pinion gears the same for non c clip and c clip axles? And are the interchangeable? Yes, they are the same Link to comment Share on other sites More sharing options...
TheSiLvAPython Posted July 5, 2024 Author Share Posted July 5, 2024 Thank you. Been wondering this for quite some time. Need to put a new ring and pinion in mine. I know the spider gears and axle shafts are different because I purchased the wrong spider gears once. I'm guessing the drum brakes are different too? But everything else is the same for sure? Link to comment Share on other sites More sharing options...
ghetdjc320 Posted July 6, 2024 Share Posted July 6, 2024 On 7/5/2024 at 5:13 PM, TheSiLvAPython said: Thank you. Been wondering this for quite some time. Need to put a new ring and pinion in mine. I know the spider gears and axle shafts are different because I purchased the wrong spider gears once. I'm guessing the drum brakes are different too? But everything else is the same for sure? The ring and pinion are the same. The brakes for the non c clip axles are typically the larger 10” drums vs the later 9” drums. Link to comment Share on other sites More sharing options...
