Whiteshark Posted January 5, 2008 Share Posted January 5, 2008 hey guys well i recently purchased a new comanche and ive noticed if i don't turn it on for like 1 or 2 days it has problems with starting it will just crank forever then a few tries later it will finally start....ive checked the fuel pump relay which is good, my fuel pump sounds good since i can hear it working, i got new sparkplugs, wires and cap and rotor, all my electronics seem to be where there supposed too aswell I'm stumped and very aggrivated i need this thing to be dependble and turn on every time ...before i take it to an electrician i want to see if any of yall have had similar problems...thnx to all in advance Link to comment Share on other sites More sharing options...
jtdesigns Posted January 5, 2008 Share Posted January 5, 2008 cps?? Try and unplug it then plug it back in when this happens. Link to comment Share on other sites More sharing options...
BLHTAZ Posted January 5, 2008 Share Posted January 5, 2008 I have been told that it is "normal" for the renix engine to take several rotations to start. Mine always cranks for 3-5 seconds before actually firing up. I thought it was a problem, but 3 different people have said that it is normal for this engine. Not sure if you really have a problem or not as mine will also take a bit longer or even a couple trys to start if it has been sitting for a while. Link to comment Share on other sites More sharing options...
Whiteshark Posted January 5, 2008 Author Share Posted January 5, 2008 cps?? Try and unplug it then plug it back in when this happens. where is that found? does my truck have it since its a manual? Link to comment Share on other sites More sharing options...
jtdesigns Posted January 5, 2008 Share Posted January 5, 2008 cps?? Try and unplug it then plug it back in when this happens. where is that found? does my truck have it since its a manual? is it a 4.0? Here is a link that describes basic Renix sensors The CPS is second to the end.. It is said that if you unplug the CPS and then plug it back in it gets a better signal to the computer.. Link to comment Share on other sites More sharing options...
Whiteshark Posted January 5, 2008 Author Share Posted January 5, 2008 cps?? Try and unplug it then plug it back in when this happens. where is that found? does my truck have it since its a manual? is it a 4.0? Here is a link that describes basic Renix sensors The CPS is second to the end.. It is said that if you unplug the CPS and then plug it back in it gets a better signal to the computer.. ok thanx bud but hey does my comanche even have a cps since its a manual? ive been told manuals don't have a cps....thnx Link to comment Share on other sites More sharing options...
jtdesigns Posted January 5, 2008 Share Posted January 5, 2008 cps?? Try and unplug it then plug it back in when this happens. where is that found? does my truck have it since its a manual? is it a 4.0? Here is a link that describes basic Renix sensors The CPS is second to the end.. It is said that if you unplug the CPS and then plug it back in it gets a better signal to the computer.. ok thanx bud but hey does my comanche even have a cps since its a manual? ive been told manuals don't have a cps....thnx I know if its a 4.0 it does. manual and autos do,, not sure about 2.5 or 2.8l's Link to comment Share on other sites More sharing options...
Whiteshark Posted January 5, 2008 Author Share Posted January 5, 2008 cps?? Try and unplug it then plug it back in when this happens. where is that found? does my truck have it since its a manual? is it a 4.0? Here is a link that describes basic Renix sensors The CPS is second to the end.. It is said that if you unplug the CPS and then plug it back in it gets a better signal to the computer.. ok thanx bud but hey does my comanche even have a cps since its a manual? ive been told manuals don't have a cps....thnx I know if its a 4.0 it does. manual and autos do,, not sure about 2.5 or 2.8l's ok bud yup i got the good ol renix so i ll check the sensor....how much are they new would you happen to have an idea? Link to comment Share on other sites More sharing options...
jtdesigns Posted January 5, 2008 Share Posted January 5, 2008 well partner you could try Napa. they have them for around 30 -50 bucks Link to comment Share on other sites More sharing options...
jtdesigns Posted January 5, 2008 Share Posted January 5, 2008 forgot to mention their a B@%# to put in.... You never said what year and engine size you had... Link to comment Share on other sites More sharing options...
Whiteshark Posted January 5, 2008 Author Share Posted January 5, 2008 forgot to mention their a B@%# to put in.... You never said what year and engine size you had... my truck is an 88 and i have the 4.0 renix Link to comment Share on other sites More sharing options...
chicofuentes0224 Posted January 6, 2008 Share Posted January 6, 2008 Nappa has it. Mine is the same 4.0 automatic 1988. Part number CSS980SB. It cost me $34.13, but I lie and say I work at a shop. Regular price said, $47.23. It helped a little but not much. If the truck sits for more than a day it still takes a couple tries and a longer crank to start. Everyone seems to say on this board that it is completely normal for this engine and year, so I wouldn't worry about it. Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted January 6, 2008 Share Posted January 6, 2008 The renix 4.0 will take a bit of cranking to fire. Just couple 3-5 seconds is normal. BUT, Are you letting the pump pressurize the system before starting? Turn the key to on, wait a couple seconds and crank. Turning the key "ON" and waiting a second, is on par with the couple quick "pumps" on the accelerator with a older carburated vehicle. When I went thru mine, (Even thou it only had 60,000 at the time.) I got minute decreases in cranking times by having everything properly set and CLEAN. TB, Plugs cap rotor, wires, injectors, TPS properly set. Wiring connections clean, weatherproof and tight. All these made minute changes, lowering the cranking times. The one biggest decrease in cranking time came when I rewired the charging system. Probably took a full second off the time!! CW Link to comment Share on other sites More sharing options...
