Silverhawk1991 Posted March 20, 2024 Share Posted March 20, 2024 Hey all, I pulled my radio today, and after replacing it, it just displays “MTL” and won’t switch to radio. I don’t have a cassette in it, and I don’t think cassettes have ever worked in this unit (I tried a cassette->3.5mm aux cable once and it wouldn’t stay down). Any ideas what would cause this? I have the dash pulled off, so would like to get it addressed tonight. @Minuit, any ideas? Link to comment Share on other sites More sharing options...
fiatslug87 Posted March 20, 2024 Share Posted March 20, 2024 It thinks there’s a “metal” cassette tape in there (a higher end tape than normal). Have you tried to eject? You need to get the mechanism to pop up. Link to comment Share on other sites More sharing options...
Silverhawk1991 Posted March 20, 2024 Author Share Posted March 20, 2024 Ah, that’s what is meant by MTL. I did try the eject button, but nothing happens. I pulled the radio out just to check if something was lodged in there or something was off. Is there a physical eject mechanism that I could manually actuate? Link to comment Share on other sites More sharing options...
speeding_infraction Posted March 20, 2024 Share Posted March 20, 2024 Try putting in a cassette and running it, and press eject afterwards. Link to comment Share on other sites More sharing options...
Silverhawk1991 Posted March 20, 2024 Author Share Posted March 20, 2024 Unfortunately I have no cassettes on hand, but fortunately I fixed the issue! Not exactly sure what did it. I pulled the head unit and actuated all the mechanical bits inside, to try and shake anything loose that may have been stuck. That seems to have done it. Thanks all! Link to comment Share on other sites More sharing options...
Minuit Posted March 20, 2024 Share Posted March 20, 2024 If it does it again, unplug the tape mechanism. Link to comment Share on other sites More sharing options...
