Duncan Moody Posted January 7, 2024 Share Posted January 7, 2024 Looking for details on how to do a home run from CPS to ECU. 1989 4.0 AT. I have no C101. Is it a matter of tracing the wire colors (or continuity) from CPS back to ECU, run new wires through fire wall, then cut and solder at the ECU connector? I could not find ECU connector diagram identifying the CPS connections. Link to comment Share on other sites More sharing options...
cruiser54 Posted January 8, 2024 Share Posted January 8, 2024 TSB 18-51-88 There's a factory bulletin on doing that. CPS Bypass TSB Link to comment Share on other sites More sharing options...
Duncan Moody Posted January 8, 2024 Author Share Posted January 8, 2024 Thanks!! Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted January 10, 2024 Share Posted January 10, 2024 On 1/8/2024 at 4:53 AM, cruiser54 said: TSB 18-51-88 There's a factory bulletin on doing that. CPS Bypass TSB Curious, was this a recommended service note for all 87-90 MJ's or just those having CPS problems? Any benefits of doing this on an MJ that does not have any CPS issues? Thanks Link to comment Share on other sites More sharing options...
cruiser54 Posted January 10, 2024 Share Posted January 10, 2024 I don't remember. We generally upgraded for sure if it was under warranty. eliminating the c101 connector kinda does the same thing. Years ago, I used to bypass the c101 connector by going into the loom and soldering the CPS wires together. Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted January 10, 2024 Share Posted January 10, 2024 1 hour ago, cruiser54 said: I don't remember. We generally upgraded for sure if it was under warranty. eliminating the c101 connector kinda does the same thing. Years ago, I used to bypass the c101 connector by going into the loom and soldering the CPS wires together. All the more reason to bypass and solder the c101. On the to-do list. Thanks. Link to comment Share on other sites More sharing options...
