acfortier Posted December 21, 2023 Share Posted December 21, 2023 I've got a pretty loud oscillating higher-pitched sound that seems like it's coming from the transmission when I'm driving in the cab. I feel like it goes away after awhile, but not always. It's kinda annoying at this point, and driving me insane. Can anyone else identify/hear it in these videos? https://drive.google.com/file/d/1NQ2llMEPGLJLTITn_kyvNMR_POcEnwDO/view?usp=sharing https://drive.google.com/file/d/1J_u6DNNMJuUnMqDREZqTyUlWXnD-BXV-/view?usp=drive_link Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted December 21, 2023 Share Posted December 21, 2023 Does the noise match the speed that you’re going? In other words does it go faster as you go faster, or slower as you go slower? Without being close to it, I would say something internal. However maybe u joints, or throw out bearing are a couple other things I can think of off the top my head Link to comment Share on other sites More sharing options...
pizzaman09 Posted December 22, 2023 Share Posted December 22, 2023 Start with the easy things I'd say, check that nothing is rubbing on the drive shafts and confirm the fluid levels are correct in the transmission and transfer case. I kind of agree that the sound could be a worn out throw out bearing, but the sound should change when you push in the clutch. Link to comment Share on other sites More sharing options...
acfortier Posted December 31, 2023 Author Share Posted December 31, 2023 Forgot to follow up. No, I don’t really notice the frequency of the noise change when I go faster—it might get louder but that’s it. Seems to go away under ~20 mph or so? Haven’t noticed if it goes away when pushing the clutch in, I’ll give that a shot. Ill take a peek underneath and check fluid levels. Link to comment Share on other sites More sharing options...
acfortier Posted January 9, 2024 Author Share Posted January 9, 2024 Changed fluid and put in MT90. Noise is still present when cold, but goes away much quicker and doesn’t get nearly as loud as it used to. Noise does not go away when clutch is pressed in. Link to comment Share on other sites More sharing options...
