jeff351 Posted December 2, 2023 Share Posted December 2, 2023 Had a moment of panic when i went to remove the ring gear and the first couple of bolts snapped off. Thought about it that night and suddenly a lightbulb went off. Left hand threads? Sure enough - yes, you can remove the ring gear if you use an impact gun regardless of which way you "loosen" the bolts. Once the heads snap off, just tap the gear off with a hammer. Link to comment Share on other sites More sharing options...
derf Posted December 3, 2023 Share Posted December 3, 2023 Probably has red locktite on the bolts. Link to comment Share on other sites More sharing options...
jeff351 Posted December 3, 2023 Author Share Posted December 3, 2023 5 hours ago, derf said: Probably has red locktite on the bolts. Maybe. But the 8.25 ring gear bolts are not 'left loosey righty tighty' as 99% all other bolts are Link to comment Share on other sites More sharing options...
JYau Posted December 4, 2023 Share Posted December 4, 2023 Yes the ring gear has reversed threads. I just did this on my 8.25 when I regeared to 4.56. What gears are you going to? At least on going up to 4.56 you'll have to grind one of the ring teeth down to get clearance for the cross pin. Just a heads up. Link to comment Share on other sites More sharing options...
Drahcir495 Posted December 4, 2023 Share Posted December 4, 2023 On 12/2/2023 at 8:05 PM, derf said: Probably has red locktite on the bolts. I agree. We always use red locktite on every ring gear we install. Link to comment Share on other sites More sharing options...
