59 minutes ago, cquinnball said:
Thank you for responding.  Those are nice, do they have the fold forward function?  Looks like a 4dr.  Maybe it is easy to convert to a folding seat?
To convert them I’m pretty sure you need a 2dr frame to swap them onto, you may be able to drill out a rivet so it will pivot but to get it to lock you need 2dr frames. But as someone with 4dr xj seats in their truck it isn’t that bad, if I ever need to fit something big in behind the seat i just slide them forward a bit and then back after it is in.
