Door hinge backing plate - door side torx
Attempting to fix a sagging door and ripped pillar weld with this method
https://www.naxja.org/forum/showthread.php?t=986973
BUT in the process of removing the door discovered the torx bolts holding the upper hinge on were completly rusted to the backing plate, (2 immediately snapped off and I just cut the 3rd).   I've searched and am only coming up with fixes for the cab side backing plate.   Does anyone have advise or experience in replacing the door side hinge backing plate?
That's just a 3/16" thick plate that is independent from the door itself.  It's likely rusted to the door metal.  A good wacking on the bolts should dislodge it.  May have to soak it some with blaster before it comes loose.
