CEThomas Posted December 26, 2007 Share Posted December 26, 2007 What problems are D-30's noted for???? We took the MJ for the first test drive yesterday and had problems :cry: Went for a 5 mile drive first then a 10 mile drive to the in-laws for x-mass. Had some strange vibs when it would go into OD or you let up on the gas :roll: but everything else was fine 8) Made a stop at the father-in-law's house to pick up somethings to take to sister-in-laws, it set for about 40min., went out and it would not move. Acted like a brake had hung up :roll: poped it into 4 low to see if I could free it up and the t-case went pow :mad: think the vibes may have been the chain floping in the t-case :roll: Well we went to eat and came back to see what was wrong. Jacked up each wheel and each tire turned free. Took off both front and rear DS so we could move the MJ so father-in-law could get his car out and it would not move :nuts: we then found the front pinion seized :roll: The fluid level is up to the fill hole, so it did not leak out :nuts: going to get it towed home today so we can pull the cover off, but was just wondering if this is a common problem. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 26, 2007 Share Posted December 26, 2007 wow. that's not a great christmas gift. um, not typical, but I'm sure it does happen. Link to comment Share on other sites More sharing options...
fiscus Posted December 26, 2007 Share Posted December 26, 2007 Did you check the axle's u-joints? If one of those blew it would cause similar problems with binding. Link to comment Share on other sites More sharing options...
CEThomas Posted December 26, 2007 Author Share Posted December 26, 2007 Everything fine inside, just the pinion bearing seized big time :cry: Any body know the specs to replace the pinion and diff bearings :roll: Link to comment Share on other sites More sharing options...
BLHTAZ Posted December 26, 2007 Share Posted December 26, 2007 Any body know the specs to replace the pinion and diff bearings :roll: That is not a do-it-yourself type job. You really need to have someone with the right tools and knowledge for a job like that or you will be doing it all over again in a short time. Link to comment Share on other sites More sharing options...
CEThomas Posted December 26, 2007 Author Share Posted December 26, 2007 Thanks, Have the tools just needed the tork specs and backlash, but just checked and new bearings will run about as much as the $95 D-30 from the JY :nuts: Link to comment Share on other sites More sharing options...
BLHTAZ Posted December 26, 2007 Share Posted December 26, 2007 8) Yea...a bearing kit (install kit) typically runs in the $100 - $130 area. It has been a while so do not trust this, but it seems that the desired back-lash was around .005 - .008 when we did mine a few years ago in our YJ. Link to comment Share on other sites More sharing options...
CEThomas Posted December 27, 2007 Author Share Posted December 27, 2007 Thanks, For the price and work to replace the bearings, it's going to be replaced with one froom the JY or we will part out my XJ :roll: Link to comment Share on other sites More sharing options...
Oizarod115 Posted December 27, 2007 Share Posted December 27, 2007 that happened to my brothers D30 but it was bone dry on fluid, happened when he was driving (slowly thank god) locked up and dragged tires til she stopped, pulled the inner shafts (leaving the stubs in the hubs) so that he could continue driving it. Link to comment Share on other sites More sharing options...
CEThomas Posted December 27, 2007 Author Share Posted December 27, 2007 When I got the DS at the local JY, they had it for $30 and it was missing the front cover and right side shaft. It had no fluid in it and a little surface rust on the gears but looked OK. Something must have been up with the bearings that I could not see :oops: Link to comment Share on other sites More sharing options...
