No run condition
1 hour ago, Glenn Bint said:
Testing with key on?
HOT AT ALL TIMES doesn't care if KEY ON or KEY OFF.
Continuity testing needs KEY OFF.
KEY OFF. B+Latch Relay removed. Disconnect C200. This testing will require extra-long leads used for DVOM (ohmmeter).
Check for continuity between C200_7 and C215_2.
Check for continuity between C200_19 and C215_4.
Check for continuity between C200_19 and C215_5.
If continuity exist between all three (3) pinpoint tests, suspect ECU.
957049564_C200ECU2_5L.jpg.3019c8507cfe3037fd93120e846191f2.jpg597754326_C215BplusRelay.jpg.9d03978a02c8bd5bb05318ba9220dc4f.jpg
Cool. I can make my own leads. Trouble is going to be accessing, as I’m 6’ 3” at 260 pounds. I take up a lot of space 😁. I’ll just have to do what I normally do and remove drivers seat and lay on my back.  Am I testing at ecu connector or at the actual ecu? I do have another ecu and wondering how safe it is to swap it out.
On 7/29/2023 at 4:11 PM, Glenn Bint said:
So where/what is C215?
Determine which Relay is the B+Latch Relay (Power Latch Relay). Look for your block relays, should be 2, 3 or 4 relays locked together. PIN_4 & PIN_5 should have PINK wires. Pink should help with relay ID.
Example is 4.0L engine.
ECU connector C200.
If you PASS the three (3) pinpoint tests and you know your B+Latch Relay is good, next step would be to try a known good ECU. Since engine STARTS and RUNS with jumper wire in place. Could be/should be/ maybe OKAY to swap ECUs. Do you feel lucky.
