EGR ramblings and reach out
On 1/6/2024 at 10:27 AM, suds1485 said:
Blox racing makes one for old Hondas that used the same egr valve I just ordered one to replace the one I made I’ll let you know how it goes.
Is there any follow up on this?
https://bloxracing.com/products/egr-block-off-plate-honda-overstock
Reasonable price but would like to know if it fits before I order one.
You can just take your old egr gasket, trace it onto a piece of aluminum or steel and cut it out. It's pretty easy. If your gasket is shot, use one of the .dxf files I uploaded earlier in this thread, print it out, trace it and cut it out.
  • 1 month later...
Just a follow up, I got the Blox block off plate and it fit perfect. Thanks Suds. As Suds1485 said the screws they send are not the same threads. I just added a grade 8 washer with the stock bolts that were there. Socket head cap screws with the correct thread pitch would work good too.
I have a perfectly good EGR valve sitting on my work bench if anyone wants it.
  • 2 months later...
