speeding_infraction Posted July 2, 2023 Author Share Posted July 2, 2023 Off topic but, what is the part number for the front valver cover grommet. Mine is cracked and leaking Link to comment Share on other sites More sharing options...
speeding_infraction Posted July 2, 2023 Author Share Posted July 2, 2023 Link to comment Share on other sites More sharing options...
cruiser54 Posted July 2, 2023 Share Posted July 2, 2023 CRUISER'S MOSTLY RENIX TIPS RENIX VACUUM HARNESSES NOVEMBER 17, 2015 SALAD 29 COMMENTS EDIT The vacuum harness that attaches to the front of the valve cover and includes the grommet/fitting, and is called the front harness, is Napa part number BK 715-1367 or is a Dorman 46003. The vacuum harness that is closest to the air cleaner, EGR etc, and is called the rear harness, is Napa part number BK 715-1366 or is a Dorman 46004. The tube from the rear of the valve cover to the intake manifold is part number BK 715-1365 or Dorman 46005 and comes with the valve cover grommet. The Throttle Body to MAP hose is no longer available. Click HERE to access a fix for that. Link to comment Share on other sites More sharing options...
speeding_infraction Posted July 2, 2023 Author Share Posted July 2, 2023 Thanks Link to comment Share on other sites More sharing options...
speeding_infraction Posted July 3, 2023 Author Share Posted July 3, 2023 On 6/30/2023 at 7:13 PM, cruiser54 said: Voltage to the ECU from one TPS goes up as the throttle opens and the voltage goes down on the other as the throttle opens. In which system does the voltage go up as the throttle opens, renix or HO? Link to comment Share on other sites More sharing options...
cruiser54 Posted July 3, 2023 Share Posted July 3, 2023 Renix goes low to high Link to comment Share on other sites More sharing options...
speeding_infraction Posted July 3, 2023 Author Share Posted July 3, 2023 24 minutes ago, cruiser54 said: Renix goes low to high Well now I'm baffled. PXL_20230703_233827425_TS.mp4 Link to comment Share on other sites More sharing options...
cruiser54 Posted July 4, 2023 Share Posted July 4, 2023 Why? At rest, Renix reads about .83 volts and the voltage climbs as the throttle is opened. The TRANS side of the TPS works opposite, like an HO. Is that what they spliced into? Link to comment Share on other sites More sharing options...
speeding_infraction Posted July 4, 2023 Author Share Posted July 4, 2023 9 minutes ago, cruiser54 said: Why? At rest, Renix reads about .83 volts and the voltage climbs as the throttle is opened. The TRANS side of the TPS works opposite, like an HO. Is that what they spliced into? My truck is a manual, so it doesn't have a trans plug. Do you mean that maybe they cut that off and wire the HO TPS to it? Link to comment Share on other sites More sharing options...
Ωhm Posted July 4, 2023 Share Posted July 4, 2023 On 7/1/2023 at 3:05 PM, TurboedMJ said: On 7/1/2023 at 3:19 PM, Ωhm said: In the photo, looking down on the TPS connector, is it labeled as the following: C B A or How did you connect your DVOM? Which connector letters or could be numbers? Link to comment Share on other sites More sharing options...
speeding_infraction Posted July 4, 2023 Author Share Posted July 4, 2023 9 minutes ago, Ωhm said: or How did you connect your DVOM? Which connector letters? DVOM? Link to comment Share on other sites More sharing options...
cruiser54 Posted July 4, 2023 Share Posted July 4, 2023 I'll try and figure it out by wire colors. Link to comment Share on other sites More sharing options...
Ωhm Posted July 4, 2023 Share Posted July 4, 2023 15 minutes ago, TurboedMJ said: DVOM? Digital Volt Ohm Meter Link to comment Share on other sites More sharing options...
cruiser54 Posted July 4, 2023 Share Posted July 4, 2023 The wires that the HO TPS are tied into are Renix engine TPS wires. That ain't gonna work. Now I'm wondering something. What if a guy tapped the correct Renix Trans TPS plug into the correct wires for the HO engine TPS? Link to comment Share on other sites More sharing options...
speeding_infraction Posted July 4, 2023 Author Share Posted July 4, 2023 3 hours ago, Ωhm said: or How did you connect your DVOM? Which connector letters or could be numbers? Black to b, and red to a for reference and red to c to get the percentage Link to comment Share on other sites More sharing options...
Ωhm Posted July 4, 2023 Share Posted July 4, 2023 9 hours ago, TurboedMJ said: Black to b, and red to a for reference and red to c to get the percentage HO TPS pinout at the connector should be: A - Ground B - TPS Signal (percentage) C - 5vdc Reference Link to comment Share on other sites More sharing options...
cruiser54 Posted July 4, 2023 Share Posted July 4, 2023 And it still needs a Renix TPS. Link to comment Share on other sites More sharing options...
