Runs rich at idle
Cheapo Amazon injectors or faulty MAP sensor and/or the line to the MAP.
If at idle only, most likely the injectors. Good chance the MAP tubing got messed up during injector installation.
There is a fellow Jeeper who supplies the correct, refurbished, and TESTED injectors for this community. Only place to get them IMHO.
THROTTLE BODY TO MAP SENSOR HOSE FIX
The Renix throttle bodies have a strange and failure prone connector on the side where the MAP supply originates and then runs up to the MAP sensor located on the firewall. This hose/pipe assembly is no longer available for purchase.
The real kicker here is how critical this line is in supplying the correct vacuum signal to the MAP, the most relied upon sensor for the ECU to read regarding air/fuel ratio. Any cracks, melted spots, or loose rubber connectors can cause major starting and driveability issues.
There’s a simple fix though. All that’s required is a 1/8” NPT tap, a new throttle body gasket ( Napa FPG 60742 ), a vacuum fitting (Napa 05703-B102), two vacuum elbows (Napa CRB2670), and a length of new plastic piping (Napa CRB2672).
1-20160126_155433
Remove the throttle body and take it to the workbench.
Using an oiled tap along with a driver, carefully thread the lower of the 2 holes of the throttle body where the old fitting was plugged in. Don’t go too deep. These are pipe threads.
Flush the hole with carb cleaner and inspect for any left over cuttings.
This is an excellent time to do a complete throttle body and IAC cleaning.  See Tip 11.
Take the vacuum fitting (05703-B102 ) and apply a LITTLE bit of thread sealer on the threads only. I prefer Permatex #2 but almost anything is fine.
.1-TB to MAP hose-001
Carefully screw the fitting in until snug.
Install one of the vacuum elbows on the MAP sensor so it points toward the throttle body, and the other vacuum elbow on your new throttle body fitting so it points up to the MAP sensor.
Cut a length of the new plastic tubing (approximately 13 inches) to fit between the vacuum elbows and install it making sure there is enough slack for some engine movement. Route it according to the photo. We don’t want any rubbing or chafing with engine movement.  Not a bad idea to use some contact cement or Gasga-Cinch sparingly on the tubing to elbow connectors.
1-TB to MAP hose
10 hours ago, TurboedMJ said:
There should be fuel in it while it's off correct? Or should I switch the ignition to run the fuel pump for a minute
KEY ON/OFF, you never want fuel in this vacuum line. Fuel would indicate leaky FPR.
I have an HO throttle body, intake manifold, and head. I believe this is my MAP hose? Who does the injectors for the 4.0? Where can I get them?
1 minute ago, Ωhm said:
Yea I missed that. Still 17.4 anywhere is not normal for a 5vdc circuit.
I think your running rich may be caused by the TPS.
I did the test again using a different method and terminal C read 5.02 and terminal B read 4.74. is that within an acceptable range?
8 minutes ago, cruiser54 said:
Injectors:
trevor.skankfootracing@gmail.com
Thanks
10 minutes ago, cruiser54 said:
HO and Renix TPSs work opposite of each other.
The Renix system will not work with an HO TPS.
Previous owner set it all up. Not sure how the system works together but it seems to 🤷🏼‍♂️
Doesn't seem like it works well to me.
Voltage to the ECU from one TPS goes up as the throttle opens and the voltage goes down on the other as the throttle opens.
Tell me how that can work properly. Backwards.
You need a Renix TPS adapted to the HO throttle body, or just get a Renix intake and throttle body.
That HO intake and throttle body are not worth keeping.
Is it possible that whoever set this up intentionally wired it backwards? When I pull the wiring out of the split loom I find this
