Wow trying to find a place than can press off the bearings is a nightmare I live in Dallas and most places won't do it and the 4wp wants 300$  thats robbery so I guess I just buy a 20 ton press at the harbor freight any suggestions on what I will need
are you trying to get the bearing off the axle shaft or off the carrier?  Either way, I've had good luck cutting through the inner race with a die grinder.  You won't get all the way through because of the shoulder, but when you get most of the way through, you can take a good hard chisel and hit it in the cut you've made.   That almost always causes the inner race to split apart or to loosen.
Dunno the height of the 20t but I have the 12t and it's too short for a rear axle. Grab their bearing separator kit while you're there though.
Well I bought the wrong axle bearing and have no clue where to buy ones that fit but found a 4x4 shop that will remove and replace for 50$
