'87 Pioneer Longbed
41 minutes ago, Pete M said:
totally normal for tires to chirp a bit when doing tight turns in AWD  :L:  there's only so much that the t-case can give to balance the system before the tires will inevitably bind.
Thanks for the info. I will just drive it and not worry about right now.
  • Replies 103
